Postao/la pinco » 16 lis 2013, 10:19
Kažu da je taj driver odlićne kvalite izrade, na razini SS revelatora za 3x manje para, ali nije baš lagan za samogradnju, evo šta Zaph kaže:
First and foremost, the build quality of this woofer is excellent. It looks like a $200 woofer. Harmonic distortion is excellent due to the thick copper sleeve over the pole piece. Particularly clean through the midrange, though higher distortion in the bass. Response is a little ragged with an odd shaped breakup node that will need special crossover work. The highish Qts means this is best used in a sealed enclosure. Overall, a value leader in this price range.
Sastavit ću ovaj Prima, driveri su OK, nadan se da je dobro posloženo, nekolko ih je radilo na francuskome forumu i zadovojni su.
Šta se tiće ovoga Sb17, bija je tvornički dizajn kutija sa njima, al nemaju više taj visokotonac u ponudi.
Na velikome diyaudio, se oglasija SB manager, najavija je početkon 2014 novi dizajn zvučnika za te drivere.
